I am trying to get performance shifting ability in my 99 GT. and since the tuner does not have the option to turn it ON at this point, I thought if I put in a GTP pcm and just edited the tables to be exactly like the stock GT tables it would be good to go.
but no worky.
I had the "compare" feature on and went over everything possible and made it the same (even the dtc's), disabled the VATS just in case that was it.
it will crank, but it will NOT start.
it is a GTP pcm out of a 1999 gtp, going into my 1999 GT.
when the GTP pcm is installed I can see the "boost" gauge light up in my DIC.
Also on the scanner table, I can see the performance shift feature turn on and off.
it just won't start.
any ideas, or have I just wasted time and money on this GTP pcm?
