I just thought i would let you all know there is a problem with the 10 foot extension cable that was shipping with the LM1 wideband, check the connector at the end that plugs into your sensor!!!
They did not put seals around the wires!!! Just a crappy loose fitting oversize heatshrink tube to cover the splices they used.
You will destroy your sensor and harness if you use it when the roads are wet. I know cause I just did it.
UPDATE:- after contacting innovate motor sports they have informed me that all new systems ship with a weather sealed cable, They are also replacing my damaged parts free of charge!
