Having some trouble with my wideband.
It keeps reading a crazy #. I pull the sensor, turn on the power, wait 10 secs, then plug it in and let it calibrate. At this point it should be reading 14.7 in free air... I turn on the scanner and it's reading 11.00ish. Does this with both of my sensors.
I have had it wired a few different ways.
it is currently wired like the picture attached. Like this way over grounding everything in the intereface(which I have tried and still get the same prob) due to the face nothing is grounded unless I have the interface plugged into the car the entire time.
At first I thought it was the sensor, so I bought a new one, which seems to be doing the same thing as my first one.
Tried the sensor in a friends car and seems to work fine. Friends car is wired different then mine( tried the same way his was wired and got the same results.).
We used my HP intereface to insure that wasn't the prob, and it worked fine on his car.
so at this point I'm thinking my LC-1 is no good?
Any one have any ideas?
