Results 1 to 20 of 25
Thread: Adjusting IAC Count
    Tuner ws6ick's Avatar
    May 2008
    Kentucky
    106
    Adjusting IAC Count
    Here is a scan log of my last run. If you go to the end of the log, the TPS is at zero and the car is in park. My IAC count is arount 120. What should it be at and how do I adjust this?
    2000 Trans Am WS6, 383 RWHP 344 RWTQ
    2006 GTO, LS2, Cyclone Gray, M6, 1 of 475
    2009 Chevy Silverado
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    It should be at 60-70 with a cammed car.
    1) You will want to monitor your IAC, Idle Speed, throttle position voltage and your throttle position %.
    2) With the key in the ON position, adjust your tb set screw until your throttle position is 2%.
    3) Turn your key to the OFF position.
    4) Unplug your Throttle Position Sensor (TPS).
    5) Turn your key to the ON position for a few
    seconds, and then OFF again.
    6) Plug in the TPS and then turn your key to the ON position and restart logging. Your throttle position will now be reset to 0 degrees and about .45-.55 volts. Any higher can put you into the wrong fueling cell.
    7) Start your engine, if you are not at your desired IAC position redo the above procedures in smaller increments.
    8) If your TPS voltage should be between .45 and .55 volts you may need to drill the mounting holes a little bigger and remove the
    locator tab so you can make an adjustment.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    May 2008
    Kentucky
    106
    You say to monitor your IAC, Idle Speed, throttle position voltage and your throttle position %. Do you mean Idle RPM for the Idle Speed?
    Nov 2002
    Central Florida
    2,503
    I don't think there's anything wrong with IAC at 120. It's less
    than half of full scale.
    The thing that will bring IAC down (aside from more bypass
    air) is more spark and proper fueling. Fueling is going to be
    bugged by O2 sensor fidelity (cold from headers) and
    airflow (VE) fidelity, tending to overfuel after a cam swap.
    But there's nothing wrong with 120 IAC counts in itself.
    May 2008
    Kentucky
    106
    Quote Originally Posted by jimmyblue View Post
    If 120 is good then I will leave it.
    Jun 2005
    Michigan
    151
    IAC counts are adjusted by moving the set screw in the throttle body or enlarging the hole in the throttle body blade. Allowing more airflow into the engine by enlarging the hole or opening the blade with the set screw will reduce IAC counts. The trick to using the set screw is having to reset your TPS after you make the changes. This will ensure you're registering 0% throttle at idle. If you go too far, it will register more than 0% at idle - even after you reset the TPS (described above in post #2 - steps 4 and 5).
    2013 Mustang GT
    Nov 2002
    Central Florida
    2,503
    If your P&P TB involved epoxy filling, make sure the
    IAC port is opened up to 3/8" or so. I went with a
    3/16" hole originally ('Net advice) and it was choking
    IAC flow and making surge. Opened it up, and a lot
    better.
    May 2008
    Kentucky
    106
    better.
    Mine is not surging. If you say 120 IAC count is good then I am leaving it alone.
    Jun 2005
    Michigan
    151
    Quote Originally Posted by ws6ick View Post
    I would open your throttle body by increasing your set screw a touch. That'll bring your IAC counts down. Personally, I would prefer to be at 70~80 steps for a warm idle.
    2013 Mustang GT
    May 2008
    Kentucky
    106
    How do I get my scanner to read the throttle position voltage? and how do I adjust your tb set screw until your throttle position is 2%?
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    Why do you want to adjust it to 2%. If it reads 2% it is going to hurt the idle.
    You add TPS voltage to the scanner just like any other PID.
    Sulski Performance Tuning
    May 2008
    Kentucky
    106
    Quote Originally Posted by WS6FirebirdTA00 View Post
    I was going by this.
    Nov 2002
    Central Florida
    2,503
    I disagree with that, my opinion is that the only thing
    you want out of the set-screw is to keep the blade
    from binding under vacuum. You want to keep TPS
    voltage in the good idle range and not make it go
    relearning, because that might well steal from your
    WOT TPS %. If the throttle body is not physically
    munged then barely-off-seat for the blade should just
    give you the right volts.
    Jan 2005
    Concord, NC
    8,093
    TPS voltage is not zeroed with a reset, it will keep a higher voltage.
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    If you have much of a cam, and you don't adjust for 45-75-ish counts at hot idle (and in some conditions less), you won't have enough airflow at cold-start and cold idle conditions. This problem already exists with tons of 'popular grinds' even with the TB opened up, but if you leave it in the 100s count area at hot idle you will be running out of IAC for cold starts/idle even sooner.
    That offset proves to be important. I am working on a car right now that has a Cam Motion custom 232/235 on a 112. SCR is high 11s:1. I have it at about 20 counts at 212degF. There is not enough blade offset and IAC to satisfy the car under about 65degF at cold start. I am requesting a low idle RPM when cold to help stretch the IAC out as well. By high 50-degrees, it will take a little pedal to get it going. We need more IAC sometimes.
    Steve Williams
    TunedbyFrost.com
    May 2008
    Kentucky
    106
    Quote Originally Posted by Frost View Post
    My IAC at warm idle is around bounces from 35-40. My Cam is 228/228 588/588 112 lsa. Is this good or not? I thought it should be 40-60.
    Jan 2006
    Richmond VA
    1,950
    What is warm idle? like 150s? If so, that is definitely too low. You will end up at 0 and lose control of idle.
    Steve Williams
    TunedbyFrost.com
    May 2008
    Kentucky
    106
    180 in Park. How do I bring it up and what should it be at in park? Do I need to adjust the throttle body blade to be opened more?
    Jan 2006
    Richmond VA
    1,950
    You bring it up by closing the TB blade a bit... look for 40-45 at 210degF. You will have to use the scanner to force the fans OFF (they have an airflow adder) or set the fans high in the editor (and update PCM) so that they don't run.
    Steve Williams
    TunedbyFrost.com
    May 2008
    Kentucky
    106
    So turn off my cooling fans by using the scanner, The IAC counts should be 40-45 @ 210 Degrees in park even with the cam I have. If its lower, close the throttle body blade a little by adjusting the screw on the TB?
