Page 5 of 11 FirstFirst 123456789 ... LastLast
Results 81 to 100 of 220
Thread: EQ <> VE Version 3
  1. #81
    Nov 2005
    Houston, TX
    3,968
    I'd to use this to tune a friend's '06 VE but the link doesn't work. I get an error that the file cannot be found. Also, is there a how to use doc or help file included with it? I'm not seeing any instructions in this thread. Probably because everyone is used to using BlueCat's program.
    Bill Winters
    Out of the LSx tuning game
  2. #82
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Quote Originally Posted by 5_Liter_Eater View Post
    Just toy with it for a bit. It was kind of intuitive to me. Then again, I never really bother to read instruction manuals with anything. Just make sure you have all the windows for parameters you want to modify open so that the hooks work.
    http://www.dsxtuning.com
    Just say no to bull s***.
  3. #83
    Nov 2005
    Houston, TX
    3,968
    Can anyone e-mail it to me @ [email protected]? The link is still busted.
    Bill Winters
  4. #84
    May 2008
    Chandler, AZ
    537
    My FTP server got jacked up, should be working now.
    ____________________________
    2008 Convertible Corvette
    Haltech CAI | Kooks Headers and X-pipe | 227/231 .613/.617 lift 115 LSA CAM | Tuned to death
  5. #85
    Advanced Tuner Redline MS's Avatar
    Jun 2006
    New York- South Florida
    536
    Is there a version of the program that has the latest and greatest updates and tweaks from all the issues noted in this thread?
    Howard
    Full Service GM Late Model Performance Facility
    www.redline-motorsports.net
    Follow US on FACEBOOK!
    Follow us on Instagram! redline_motorsports
  6. #86
    May 2008
    Chandler, AZ
    537
    Yes, except for the cam stuff, just download from the first post.
  7. #87
    Guys take a look at this and run the equations. this is for a VVT/DOD L76. i just cant seem to create good data with what i have. the VE table it creates from these numbers is well lets just say i had AFR's ranging from 9.0 to 19.0 all over the place. ANY HELP WOULD BE GREAT
  8. #88
    2,742
    I don't know why they don't have you guys on the HPtuners payroll! I've been using this and it is absoulutely fantastic. I do have one problem though and was hoping there is a easy fix. I'm trying to create Eq's by dumping in a VE table. I cannot paste into the VE table edit window. it tells me the copy/paste sizes mismatch but they do not. Just to be simple about it I only select 4 cells to copy and 4 cells to paste into and it still doesn't work.
    Am I doing something wrong?
    Thanks again for the awesome software.
    Tuner at PCMofnc.com
  9. #89
    Tuner Joe_G's Avatar
    Oct 2006
    Ft. Lauderdale, FL
    115
    This month's GM High Tech Performance has a HP Tuners ad that says the E 38 VE table is built in.... What's up with that? Is it coming in the next version?
    2005 Vert Z51 MZ6
    Horsepower Sales 954-984-8040
    4:10's, FAST 92, A/R Headers w/cats, G5x3, .040 gaskets AFR 205 heads ORIG CLUTCH
    472rwhp/414rwtq
    Best pre-cam:1/4-1.730, [email protected]
    Best w-cam, pre-FAST 1/4-1.666, [email protected]
    Best w-cam & FAST 1/4-1.519, [email protected] DA-793
    Best w-cam & AFR heads 1/4-1.445, [email protected] DA-581 1/8-1.445, [email protected] DA-581
    Top speed 185 (so far...) 0-60 mph 2.59 sec (track)
    http://www.youtube.com/watch?v=DUX3UNFl124
  10. #90
    28,268
  11. #91
    May 2008
    Chandler, AZ
    537
    Yes it is coming soon:-)
  12. #92
    Mar 2008
    St. Louis, MO
    4,860
    You are a tease.
  13. #93
    I get an error that says "Could not find one or more of the equation strings. Can not continue." Any Ideas what I'm doing wrong?
    Pete
  14. #94
    May 2008
    Chandler, AZ
    537
    Sounds like you missed a window, make sure you have the constant, map^2, map, map.rpm, rpm^2, rpm, zone RPM boundaries, and zone MAP boundaries windows open and they are not zero's.
  15. #95
    I've checked these are open and I still get the same message. Any other ideas?
    Pete
  16. #96
    Here is the file I'm trying to open.
    Hope this helps..
    Pete
  17. #97
    Could it be ver. 2.23.3363.3028 of HP Tuners software that had a change?
    Pete
  18. #98
    Quote Originally Posted by Pete@SpecialistTuning View Post
    Pete
    I believe so. I didn't work with the beta version I was using. I switched back and all was well.
  19. #99
    Thanks Ben Diss, I'll try that.
    Pete
  20. #100
    Well I've switched back to the original version and it's still not working. I removed and reinstalled ver. 2.2.2 and I still get the error, can not find equation string and then it aborts. The list of things it's doing gets to copying and all the way to copying map boundries then the error message appears. Any help would be greatlly appreciated.
    Pete
