Using VCM Suite 2.2 fails on step:
6. Reading Entire VCM gets FAILED
VCM Read Failed at loc: 0 Error Timeout
any ideas?
Note:2008 model
any ideas?
Note:2008 model
LS1 LS2 LS7 tuner, L98, LT1 & Haltec
3 steps you should try
1 make sure ya scanner if the program is open is set in the "disconnect" mode.
2 ignition is in the on position when doing a read or write
3 if the above is ruled out, disconnect the MPVI from the usb and the obd2 port - should be no power light on the box, then reconnect and retry.
And if all else fails contact support http://www.hptuners.com/help/index.h...mersupport.htm
There are some 08' E77 Alloytech pcm's we currently do not support which is probably the issue you are running into.
We hope to have it soon please .
Thanks ,
Zi5
Any news about E77 PCM ?
