Results 1 to 5 of 5
Thread: Alloy Tech V6 - read failed
    Aug 2005
    Sydney Australia
    95
    Using VCM Suite 2.2 fails on step:
    6. Reading Entire VCM gets FAILED
    VCM Read Failed at loc: 0 Error Timeout
    any ideas?
    Note:2008 model
    LS1 LS2 LS7 tuner, L98, LT1 & Haltec
    Tuner driftnpow's Avatar
    Feb 2008
    South West WA
    151
    3 steps you should try
    1 make sure ya scanner if the program is open is set in the "disconnect" mode.
    2 ignition is in the on position when doing a read or write
    3 if the above is ruled out, disconnect the MPVI from the usb and the obd2 port - should be no power light on the box, then reconnect and retry.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,273
    And if all else fails contact support http://www.hptuners.com/help/index.h...mersupport.htm
    There are some 08' E77 Alloytech pcm's we currently do not support which is probably the issue you are running into.
    We hope to have it soon please .
    Thanks ,
    Zi5
    Any news about E77 PCM ?
