Results 1 to 6 of 6
Thread: 6L80E...holding trans in gear for dyno pulls
    What's the "trick" for keeping the A6 in gear on the dyno. Even using the paddle shifts won't leave the car in gear.
    Thanks in advance for any advice.
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    In the VCM Scanner go to:
    Displays
    VCM Controls
    Trans
    From there you can pick a gear and lock the converter
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    Quote Originally Posted by 69lt1bird View Post
    Displays
    VCM Controls
    Trans
    That works fine on the 4L60s, not working for me with the 6L80.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Its probably because you didn't modify your file to ALLOW it to lock in gear
    That's exactly what I needed!
    HP Tuners Support
    (foff667)
    28,268
    Yeah I've gone ahead & stickied your other thread in the transmission section so hopefully it will help others that run into this.
