Hey guys is there any chance hpt will be doing a software based sollution for ls1to ls2,3 and ls7 engine swaps. If buying a crate 6ltr motor and wanting to install inplace of an older ls1 you either have to update the computer to a later version which creates alot more work or pull the crank out and swap the 58 tooth reluctor wheel for a 24tooth one, pain in the arse.
newer 6ltr swaps are quite cheap and common atm plenty of them are being done.
It would be nice if there was a tab or table to change the reluctor wheel count to save the great cost of doing later model engine swaps.
It would obviously be just a computer thing as the pcm 's know that it should be 24 pulses or 58 so having the ability to select what count you wanted would be veeeeeeery good and help full to a lot of people and save alot of time and money for shops and customers.
