I tried some tuning with the NGK today. So far I have no reason to dought its accuracy. That said there is two minor details I do not like about it. The range is much narrower then the PLX was. It is 9:1 to 16:1, which does not matter once you finaly get the tune inside of that range. I think the PLX was suposed to have a range of 10:1 to 18:1.
I would also like to say the NGK kit comes with more parts, i.e. a bung and plug to mount the sensor in the exhaust and to cap the bung when the sensor is not in use. The wiring harness in the NGK kit is a much nicer set up. You do not have to put pins on the wire conectors, just plug it into the sensor, then the little box, then land your + and - wires, then land your data wires to the HP Tuners device. The hardest part of the hole swap was routing the larger conector into the car were I wanted it. It also has a very good manual with it that will explain alot more info then the PLX had. So far I like it. But I have only been able to play with it for one day, so I will see how it goes.
