Results 1 to 11 of 11
Thread: Lean on cold start...
    The car idles lean when I first start it. It does this for a minute or two and when warmed up it idles at stoich. Comanded reads right and even the IPW is the same as when warm. What is going on? Only at idle too. If I drive the car everything seams fine.
    Advanced Tuner TXZ0603's Avatar
    Dec 2007
    Houston, Tx
    375
    How lean is it?
    2003 Z06
    Forged 347
    PTE Billet 67/65 Turbos
    FMIC / Dual 50mm Tial BOV's
    ID 1000 Injectors
    RSI Stage 4 Fuel System
    07 Z06 Cam
    Tripple Nozzle Meth
    ACT Twin disk clutch
    25# Boost
    Advanced Tuner Billf6531's Avatar
    Jan 2004
    Calgary, Alberta, Canada
    605
    Your Open Loop F/A vs. Coolant Temp vs. Map table is set to stoich. Take a look at a stock one. This table provides the 'richer' while the engine is warming up, until it goes into closed loop and the O2 sensors trim things to stoich.
    Best regards,
    Bill
    Silver 2003 C5 roadster, M6, Euro red/amber tails, Z06 Ti mufflers, Z06 2 cat H-pipe, Z06 airbox, and HPTuners s/w - available to any Corvette or other GM vehicle in Calgary, and also for Ford and Dodge products, including Cummins
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    OL (and really in SD) you have to set the OLFA table up correctly. Not so bad with a MAF, but if you are OLSD, you will need to command colder ECTs a bit richer.
    Sulski Performance Tuning
    Nov 2007
    Minnesota
    555
    What causes the engine to run leaner at startup though? I know my car is sucking in a ton of air because my IAC is high for about 30 seconds. I thought the startup fueling tables ADD fuel for the first 30 seconds.
    2012 Chevy Cruze A6 1LT RS
    Formerly - 2004 GTO, 2002 Z28, 2007 Colorado, 2008 Silverado
    Jan 2008
    242
    Work on your afterstsrt enrichment under (fuel section), as far min injector pluse you can increase that and your RPM & Map boundries way off need fixing..
    Jan 2005
    Concord, NC
    8,093
    cold air is denser air
    I never thought ofthe OLFA table. I was messing with afterstart enrichment and not getting anything. I will try that and tailor it to my needs.
    Thanks guys.
    Sep 2008
    Port St. Lucie, FL
    194
    A cold engine doesn't burn all the fuel put in the combustion chamber, plus like what was already said, cold air is denser, so more needs to be put in at cold start up.
    I put in the stock values at 140* and below and that fixed it. Now it is way rich. Is there a histogram for logging AFR% error for OLFA table?
    Jan 2005
    Concord, NC
    8,093
    Don't log AFR error as they will most likely be huge. Just look at the actual AFR at an ECT and raise or lower the commanded AFR until you get where you want. Best way is to manually do this from a cold start, then go back and look at those numbers, then put them in the OLFA table.
