Aaron
'03 Z06 Corvette - The Normal Stuff.....
EFI-101, EFI Advanced, EFILive-101, Variable Camshaft Tuning
EFI University Evangelist
2007 solstice gxp:gmpp; turbo upgrade, cai, PAW; intercooler, pipes, z0k; rear sway bar, rear brace. magnaflow, 18x9 ultraleggeras, 275 kumho xs, brake pads, kw v3's w/6k springs, energy suspension bushings, hp tuners, solo high flow cat
TEAM FAIL RACING
yea mines is zero so there is no fuel cuts being made if i read that right....?bad?
well my max torque is all 100 but fuel cuts are zero i have them off.
Has anybody tried the stock Torque Mgt Cylinder disable on a flashed car? Does it feel different? When does the pcm limit the torque? Which conditions are they? ESP? Cut off?
Thanks a lot Spinner! I flashed my friend's car and I noticed I left this table stock, and he lives a few hundret miles from me... He told me that the car has a lot of punch and everything ok, but I was wondering if his car is not developing the full potential.
Thanks again.
I agree with this post. in normal operation max torque is 100% and then depending on what kind of suppression is needed is how much the ecm will reduce torque. the ecm needs to reduce torque more in rapid suppression and complete disable then fixed suppressions which is why the numbers go down because the more you go down the greater the concern.
Copied from my other posts:
INJOFFPATTERN Torque reduction by injection fade out. Different, repeating fade out patterns
can be defined for several full power strokes of the engine (720° crank or 2
full rotations). This prevents single cylinders from cooling down too much
and makes it possible to find optimal patterns.
Example 4 cylinder engine:
The cylinders are assigned bitwise, the lowest bit represents cylinder 1 in firing order (FO1), e.g.
injoff = 1:
- First power stroke 0°-720°: Cylinder 1 (FO1) is faded out
- Second power stroke 720°-1440°: Cylinder 2 (FO2) is faded out
- Third Power stroke 1440°-2160°: Cylinder 3 (FO3) is faded out
- Fourth Power stroke 2160°-2880°: Cylinder 4 (FO4) is faded out
- Fifth Power stroke 2880°-3600°: Cylinder 1 (FO1) is faded out
Maybe this helps?
A cylinder individual injection cut can be done to reduce engine torque for functions such as traction control, speed limiter and rev-limiter. This requested cut off level is made via the signal injoff.
The values in XXXXXXX represent 10-bit binary values where each bit corresponds to a cylinder. The first cylinder in the firing order is the
least-significant bit (or right-most) position.
To cut injection for a cylinder, place a ‘1’ in its bit location. The number
of cylinder injections cut should be made to increase as the cut off value injoff increases.
This cut pattern is switched every 720 degrees of crankshaft angle.
When changing used cylinder number you have to readjust injection cut.
Example INJOFFPATTERN for a 4-cyl engine:
injoff - - - - >
y/x 0 1 2 3 4
0 0 1 (=0001b) 3 (=0011b) 7 (=0111b) 15 (=1111b)
1 0 2 (=0010b) 12 (=1100b) 7 (=0111b) 15 (=1111b)
2 0 4 (=0100b) 3 (=0011b) 14(=1110b) 15 (=1111b)
3 0 8 (=1000b) 12 (=1100b) 13(=1110b) 15 (=1111b)
injoff = 0 : no cylinder injections are cut
injoff = 2 : cut cylinders 1 and 2, then after 720 degrees cut cylinders 3 and 4, and so on
injoff = 4 : all cylinder injections are cut
Let me try to explain... stop thinking and forget everything you think you figured out...
The number values in the chart (1,2,3,4,7,8,12,13,14,15) are groups/sets of cylinders
so 0=0000 where the cylinder order is 4,3,2,1 means no cut on that 720* cycle
1=0001 where the cylinder order is 4,3,2,1 means cylinder 1 is cut on that 720* cycle
3=0011 so that cylinder 2 and 1
12=1100 so thats cylinder 4 and 3
7=0111 so thats cylinder 3,2, and 1
14=1110 so thats cylinder 4,3, and 2
15=1111 so thats 4,3,2, and 1
with four cylinders in the LNF the vertical (Y) value is for the cycle number
the horizontal (X) is the cylinder cut mode or "intensity" so to speak
thats why 0s in column 4 is bad... the other tables expect this to be total cylinder cut, and with a 0=0000 then no cylinders cut (injectors stop firing).
Thus column 0 is normal running state (default) injector sprays fuel as requested.
--Christian
Just want to point out the binary for "13" would be 1101.
It also appears that a 7,7,14,13 series would allow cyl 4 to run cooler (in theory) and also in theory allow cyls 1-3 to run hotter. I'm sure it's negligible. A more balanced series/example may be 13,14,7,11..
I don't zero out these values, personally. I'm not convinced that reducing the number of demanded cutoffs improves performance, either. I see a lot of tunes with these zero'd, and there's at least one poster on these forums who put a tune on someone's car at it had an "RPM hang" problem (which the tuner had never seen happen before. YMMV.)
You're quite the thread necromancer aren't you?
