In the SDtuningguide it says to set a few tables so that they are multiply out to 1. My tables match the screen shots. Do I need to change anything? Some of them are :
Open Loop EQ Ratio Gas (Gear) and (PN) are set to 10.00's.
Open Loop Airflow Gain vs map vs rpm is set to 1.0000
Open Loop EQ ration min vs ect is set to all 1.00's when its warm
Open Loop IVT Gain vs. IVT vs MAP are set to what is shown in the screen shot.
Open Loop injector gain
Do I need to modify anything here?
Once you upload the sd tune, should you clear the fuel trims?
I am filtering tps < 18 and greater than 80% out. Hit count is 30. Taking the average out of the ve afr error histogram.
All that being said, my first 2 iterations are showing normal driving/average load % error numbers of -1 to -5, but when I go WOT I'm seeing -7 to -21. I'm commanding 12.8 and getting 11.9. How can a basically stock car be that far off? I have had COT turned off for a long time, could the cats be doing something?
COT is disabled
LTFT and stft disabled
DFCO disabled
Maf unplugged, p0101-p0103 set to 0 on first mil, maf failed by putting in 0,0
PE set to 12.8
Closed loop enable set to 306
Closed loop ready set to 493
Jason
