Results 1 to 5 of 5
Thread: OBD-II port wiring
    Dec 2008
    4
    Question OBD-II port wiring
    I am doing an engine swap, 98 Buick Regal GS 3800SC into a fiero. I need to know the pinouts for the HPTuners module so that I can run the wires to make it work.
    I can't seem to find the Serial Data UART wire. I have the Serial data Class II. Is the class II the only one need to scan and write to the PCM?
    Dec 2008
    4
    Bump
    Advanced Tuner Programmer's Avatar
    Jul 2007
    244
    DLC should be...
    Pin 2 - Serial**
    Pin 4 - GND
    Pin 5 - GND
    Pin 16 - 12V
    2009 Cadillac CTS-V 196.7 MPH on the Salt
    Superflow SF600 FlowBench -- Superflow Autodyn 30 Chassis Dyno -- Superflow SF901 Engine Dyno--RaceLogic Emulator -- MikiPro Logic Emulator -- ASNU Injector Flow Bench --
    Nov 2009
    Tacoma wa
    8
    Correct me if I am wrong put your PCM has two inputs for the serial data.
    #14 and #11. #11 is the one you need. #14 is for the body control module.
    Nov 2009
    The UDART Serial Data does not need connected to HPT, or your OBDII port.
    I was in a similar situation only a week ago, and found that only the purple serial wire needs connected (along with the 12v and ground wires).
