Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: Car Missing Badly After Prolonged Downtime
    Nov 2005
    Houston, TX
    3,968
    I tried starting my car today after it had been down without battery power for some weeks. It has been down because I upgraded blower head units from a Novi 1200 to a 1500. This required some different brackets and different air bridge from ECS so I had them send me an LS3 intercooler to throttle body pipe so I could eliminate the MAF housing since I was using the POWRMAF 100mm housing and card style LS3 MAF sensor.
    Anyway, I got everything all back together and started it up and it ran like garbage; missing badly and randomly, not being able to maintain a steady RPM and when I gave it throttle it almost dies. The new pipe that that the MAF is in is slightly larger so I tried playing with the MAF tables but it didn't change anything. I switched to VE mode and it got a little better but not much. There was a misfire DTC that I cleared and it has not come back. To me it seems ignition related and I got to thinking that it may need a crank relearn from being without power for so long?
    I'm stumped so any unput is appreciated. I know the smart thing to do would be to put the old pipe and MAF housing back in to get it back to how it was but I am not at that point yet.
    Bill Winters
    Out of the LSx tuning game
    Apr 2003
    Almost 2000 feet.
    7,876
    Spider webs in the combustion chamber... LOL
    Not sure what's up if all you did was change the head unit? I'm sure you've done all the obvious so I'm going to ask anyway...
    Air leaks
    Connectors connected
    No tools in the intake manifold
    Grounds grounded
    Last but not least, Write Entire (Won't help but might make you feel better).
    Oh, any codes again?
    Always Support Our Troops!
    Nov 2005
    Houston, TX
    3,968
    Air leaks is the concensus ove ron CF.COM although the new setup has less couplers so it should be better if anything. I'll be looking for leaks today in the intake as well as the catch can/PCV setup.
    Connectors was the first thing I thought but MAP, TPS, MAF are all connected and there are no DTC's to indicate there are any connectors disconnected.
    Haven't checked for tools in the intake
    I did change the battery too as the old one had a crack in the top of the case, but both + and - are hooked up and I didn't take any of the chassis grounds off. Something else I failed to mention was I gave the battery wires a bath in baking soda and water as well as the battery tray area. the PCM is right underneath so if any battery acid was on the PCM harness the baking soda should have neutralized it.
    I was thinking a write entire too, just for fun.
    No codes after I whacked the misfire code.
    Bill Winters
    Aug 2006
    Cape Coral, FL
    99
    Bad gas from sitting?
    Advanced Tuner Bluecat's Avatar
    May 2006
    Catlettsburg, Ky
    407
    Quote Originally Posted by EC_Tune
    Grounds grounded
    That was good for a morning chuckle.
    May 2006
    Catlettsburg, Ky
    407
    Bill, it really looks like a air leak. It would have to be lean from the size of the airflow numbers and injector pw. And since the maf hz also looks low and the fact that hz to g/sec numbers look reasonable for a card maf (2000hz-6g/sec), it definatly looks like air is skipping the maf. I would have to think your car would eat more than 6 g/sec @ 1200 rpm and 10% tps. I don't know how big your injectors are (I'll assume 60's), but I doubt 1.2ms is enough fuel to make it idle happy.
    Now see, if you have a good SD tune running under your maf you could turn the maf off and trouble shoot....
    Nov 2005
    Houston, TX
    3,968
    I did try running SD and it ran better but, as you eluded to, my VE is not exactly spot on so it didnb't aid much in the troubleshooting. A little air leak is not enough to make me give up my new cad style MAF. :P
    Bill Winters
    May 2006
    Catlettsburg, Ky
    407
    So, you have or haven't ran the card style maf before having this problem?
    Nov 2005
    Houston, TX
    3,968
    It was working great with the card style MAF in the POWRMAF housing prior to this. I just got the LS3 IC to TB pipe when I got some other parts from ECS to clean up the intake tract.
    Bill Winters
    Have you talked to Doug at ECS? He uses a different brand of software, but he's pretty crafty with this sort of thing.
    Nov 2005
    Houston, TX
    3,968
    No. It was fine with the POWRMAF housing and it should be very much the same with the new LS3 pipe. I'm just missing something. I'll figure it out tonight.
    Bill Winters
    May 2006
    Catlettsburg, Ky
    407
    Any time you change the intake plumbing, especially on those sensors, you can really change the maf calibration. I still think your sucking un-metered air. But in case your not, go back to an old log and see what airflow and pw you were idling at. See what the difference is and scale your maf table by it and see what happens.
    Nov 2005
    Houston, TX
    3,968
    Well I played with it last night. I could not see any obvious air leaks so I changed back to the POWRMAF housing and LS2 pipe and edited the tune back to how it was before the car went down for the head unit swap. It ran much better but the miss is still there, it's just less pronounced. Whats worse is my brand new head unit is leaking like a seive! So I doubt I'll have time to troubleshoot the miss anytime soon as the unit may have to go back to Paxton AGAIN, or maybe in the dumpster.
    Bill Winters
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Did you check your plugs yet? You never know... it could be something simple.
    FYI, the A&A Vortech kits are awesome.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Nov 2005
    Houston, TX
    3,968
    Could be. I may do some more poking around before I rip this head unit off.
    Yea, I really like Andy's new IC design. Still, Vortech and Paxton are almost the same company so I'd be leery to go with them.
    Bill Winters
    Apr 2003
    Almost 2000 feet.
    7,876
    Bill, stop screwing around and get an F1R... Just kidding, you need two of em!
    Nov 2005
    Houston, TX
    3,968
    Apparently the brain trusts at Paxton simply overfilled my unit. Took some oil out and it doesn't appear to be leaking anymore. But, the car still misses badly. It comes and goes. On the way back from a test run it was even bucking; when cruising down the roar @ ~2500 RPM's it would even buck hard. I tried pulling plug wires and injector harnesses on individual cylinders and it didn't even make a difference in the way the engine ran.
    Starting to think the MAF is bad. The MAF chart looks OK then gets very erratic then OK again. Tomorrow I'll try switching to SD. Attached is a log file of the bucking and here's a video:
    Bill Winters
    Jul 2008
    Altanta, Ga
    35
    I am glad I am not the only one who names my logs by the frustration they cause me haha.
    New - 08 C6 Z06 - intake only - 478whp/446wtq
    RIP- 08 C6 6spd - 480whp/441wtq - Bolt-ons/Cam
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    bad MAF is a good candidate, how do the plugs look?
    Sulski Performance Tuning
    Nov 2005
    Houston, TX
    3,968
    I only looked at the passenget bank and they all looked fine. I'll check the drivers side tonight and switch to SD and report back.
    Bill Winters
