I searched and searched and remarkably can't seem to find this mentioned anywhere...
This isn't a big deal with a dyno, but I have some customers with fairly serious setups that want only street and track tuning. Basically, I hook up my LM1 and log, and at WOT, what is recorded error-wise is about 2 cells off in VE because of latency from one place or another that makes it's way into the logs.
It's easy to see in the logs when going into PE and out, you can clearly see that the actual AFR from the wideband is behind the rest of the logging. The car I'm working on now needs to be done on the street (OLSD) in first and second gear, but the latency is so high that I am having a fit with it at WOT. It sure would be nice to be able to positively or negatively offset EIO data time-wise in the logs. Could this be a potential feature?
What is the best way to deal with this, or is my LM1 the slow culprit?
Thanks for any insight.
