I am having some problems finding a good place to weld a bung for my LM-1 wideband on an 08 Corvette with stock manifolds. There is no room for a WB sensor. Some have suggest putting it on the top side of the CAT since the honey combs are further down in the cat. I have investigated pulling the B1S1 sensor and replacing with the wideband while using the LM-1 output to deliver the ECU the info it needs to function but I can't decipher the wires. Options are:
HO2S Low Signal Bank 1 Sensor 1
HO2S High Signal Bank 1 Sensor 1
Ignition 1 Voltage
HO2S Heater Low Contorl Bank 1 Sensor 1
I have contemplated going post cat but I understand readings are likely to be leaner. Possilby .3 to .6 difference. Just curious what all the tuners out there think. Where do you do to get your AFR...Tailpipe? Intall a bung just for tuning? Thanks. I am driving myself mad trying to figure out what I want to do. It is so good to be amatuer tuning again. So much to learn.
WHat I have learned so far:
1) No one completely understands TM except folks that keep it a secret.
2) Knock sensors on LS3's are oversensitive
3) Don't bother trying to adjust VE tables (I couldn't even find a VE table) and just use MAF tuning (I gotta find a thread on how to do that).
Much different than my C5 LS1.
