I have a 2005 Impala Base trim that I picked up used. Apparently the base trim didn't offer an IPC that has a tachometer. Being an enthusiast I just simply went to a salvage yard and found a cluster that had a tachometer. I went to my local dealer and had them install it. In doing so I asked if they could program the mileage to match the mileage my vehicle. When the advisor came back he said the tech would program it as if it were new.
Now to my knowledge, that includes programming the mileage and engine hours (if applicable), So I said ok. As I am pulling out, right after their closing hours, I check the milage... Its about 10k off what my mileage should be. I have contacted every dealer in my area, and none will program it, regardless of the fact I have receipt of the change out, and reset the trip mileage as I was pulling out of the dealer, so I have a correct record of the miles I have put on since.
Due to liability, I am sure that since the dealer did not do it when I had it in, there is no "official" record of the mileage since I left the premises and run into too many legal issues with them programming it.
With that in mind I am turning to the after market. I am trying to find a solution that will allow me to increase my mileage without taking the IPC out. I am on a tight budget and have only managed to come up with $300 to get it done. I can in the near future come up with more, however, can't exceed $600. Do you know of any hardware/software solution that will give me the ability to do it?
I was looking at HP Tuners MVPI suite, as it is the cheapest solution I have found so far, but am not sure it will allow me to change the mileage.
I am willing to learn what ever is necessary and would be extremely grateful for a little more direction than what my days of googling has brought me.
