Does the NTK offer narrowband functionality? I.e. can I replace one of my narrowband sensors with the NTK sensor, and have my narrowband readings function normally while gathering wideband data?
If the NTK sensor does function as narrowband sensor, which stock narrowband sensor should I swap out for the NTK sensor?
Is it considered "bad" to continually use a NTK sensor as a narrowband replacement? If it is considered "bad", how many miles can the NTK sensor be safely used as a narrowband? I.e. after tuning, how soon should the NTK sensor be swapped for the stock o2 sensor?
