Have read the "
Tuning Multiple VE tables" thread (
http://www.hptuners.com/forum/showthread.php?t=6329) SEVERAL times and have studied and compared multiple stock tunes and compared them to the modified Canyon/Colorado tunes in the Tune Repository. One thing that is still perplexing me is the cam settings under Engine/Airflow/General Airflow section. My truck came with 0,10,15,20,25 (min to max) settings. It appears that most of the stock tunes had the same 0,10,15,20,25 factory settings but maybe a few did not??? Did some of these trucks come with 0,9,12,16,25 factory settings? The Histogram Repository for these trucks were setup using these alternate settings (0,9,12,16,25). Can only think that these settings (if modified) were dialed back to in attempts to shift the power band up to the top end of the rpm scale while sacrificing the lower and mid range. Is this a correct assumption? I am on the other end of the scale with a jacked up 4wd truck. Top end speed does not interest me as much as lower end power and pickup. Truck will eventually get up to top end speed when I need it. It just does not need to be fast. Not racing anyone (at least not where I will need the top end range)
Changed the cam settings (0,9,12,16,25) a few days ago. Truck seems to be driving fine but appears to ride with higher manifold pressure. Also completely removed the torque management but think I am going to put it back in and just start slowly decreasing it. After thinking about it that also seems to be a racing tactic that I do not need in my truck. Have had the truck in SD Open Loop Mode (or so I think) for the last few days. With the modified cam settings and the feedback from the VE - Cam histograms (many cells appear to be maxing out at 8), it seems like the VE tables are extremely far off. Have been scanning and modifying the VE tables several times daily but still getting most cells maxing out at 8. Is this expected to take several days because of the cam setting changes? Are these cam settings for top end power? Am I chasing my tail?
SD Open Loop Mode settings:
Engine - Fuel Control - Fuel Cutoff - Deceleration Fuel Cutoff DFCO Enable Normal
1. Enable temp = 493
2. Enbable RPM = 7500
3. Enable Speed = ALL 158
4. Enable TPS = ALL O
Engine - Fuel Control - OL & CL - Open Loop
5. Gas (Gear) = ALL 1
6. Gas (P/N) = ALL 1
Engine - Fuel Control - OL & CL - Closed Loop Closed Loop Enable
7. ECT vs. Startup ECT = ALL 306
8. O2 Readiness ECT = ALL 493
Engine - Fuel Control - OL & CL - Long Term Fuel Trims Lift Enable
9. Min ECT = 493
10. Max ECT = -40
Engine - Fuel Control - Power Enrich - Power Enrichment
11. EQ Ratio vs. RPM = ALL 1.0
Engine - Fuel Control - COT, Lean Cruise - CAT Over Temp Protection
12. COT = Disabled
13. Max Enrichment = 1.0
Engine - Spark Control - Spark Advance - Main Spark Advance
14. Copy low octane over to high octane - Tuning on low octane
Engine Diagnostics - Airflow - MAF Sensor
15. MAF Fail High = 0
Engine Diagnostics - DTCs
16. P0101, P0102, P0103 = 1 - MIL on First Error
Does this look right? Tried to disable all fuel corrections but it does not seem like the Long Term Fuel Trims Lift is disabling. Am I doing something wrong? Trying to dial in for low end power and hopefully keep the foot of the pedal for some additional MPG. Have not started on the transmission yet.
Thank you.
