Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Tow/Haul - performance button question
  1. #21
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Set it to ONE SWITCH. I just had it pulled down to show the options.
    Steve Williams
    TunedbyFrost.com
  2. #22
    Dec 2012
    2
    Zjm861 did it work?
    ZJM861 what was the outcome of your trial?
  3. #23
    Advanced Tuner Shrek's Avatar
    Nov 2011
    753
    Posting a question in a thread that has been inactive for 2 years is not likely to get you a quick answer ... plus this thread is needlessly convoluted.
    Are you trying to set up a switch to access the Performance mode (Tow / Haul) shift pattern ?
  4. #24
    Jan 2015
    Arizona
    425
    Quote Originally Posted by ptiemann View Post
    yessir, im interested in the outcome as well..
    Quote Originally Posted by Shrek View Post
    is it any better, being inactive for 12 years? still relevant information, that im searching for, which brought me to this thread.
  5. #25
    Tuner awest623's Avatar
    Oct 2019
    Pyeongtaek, South Korea
    70
    In the computer change the performance option to one switch. Give pin C1‐71 a momentary ground, DO NOT USE A TOGGLE SWITCH. Congrats, you now have tow haul mode.
    Edit: Attached my tune file so you can take a look. Notice the "Performance" tables under the transmission tabs, those are for your tow/haul mode, or however you want to set them up. Change Trans>Shift General>General>Perf Option to "One switch"
  6. #26
    Oct 2019
    70
    Here's a picture of my setup. Just a cheap momentary switch from Advance Auto. Grounded one pin a bolt under the dash, the other pin runs to the input on the PCM.
    1998 GMC K1500 Z71
    * L31 350 Vortec
    * AUS 43lb injectors
    * Comp 08-410-8 with 1.6 rockers
    * P59 swap
    * Whipple supercharger
    * JBA headers
    * AFR 190cc heads
    * NV4500 swapped
    * Cal-Trac traction bars
    * 1" blocks, 265/70r17 BF Goodrich KO2s, 17X8.5 ALPHAEQUIPT COMMAND LT
