Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: F.A.S.T. Dual Wideband
    You should ask F.A.S.T for the Lambda ranges, this way you can match your stoich AFR instead of theirs.
    Apr 2006
    western NY
    339
    I will bring this back up since they have changed our scanner and put no predefined FAST wideband setup in this new style, really ticked off cause I cannot figure this out and my new turbo setup is useless without my wideband setup.
    2000 Firebird,2002 O.S.,LQ4 370,Borg Warner S475,truck mani.,Eagle crank,Callies Compstar Rods,Wiseco-11 4.030 pistons 9.4:1 comp.,LS3CNC heads,LS3 intake,NW92mm throttle body,ID1000 injectors,BTR trunion upgrade,LJMS STG3 cam,LS7 Lifters,ARP Studs-bolts,Frozen Boost A to W intercooler,JGS 60MM BOV,2 40mmJGS Wastegates,4L80E trans wth segment swap,CircleD 3400 single disk,MOSER 12 3.31gears ,BMR K-Mem.,2 Walboro 450 pumps,Returnstyle fuelsystem MAGNAFUEL regulator.
    LS1Tech sig KRAZY K 2000 TA
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    New wideband is ~$200. They've came so far since that one was released I wouldn't even worry about trying to use it.
    What is the formula for the WB? Look at the how to stickies--one of them walks through step by step how to setup a WB in Scanner V3
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Apr 2006
    western NY
    339
    FAST WB settings
    so here is my scanner layout, I know for a fact those settings for the wideband are correct, I dug my old laptop out and those settings were in it for the fast WB and I then went and tried it in my car, sure enough old laptop scanned great. I must just have something stupid wrong.
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Yeah, those def. aren't the right settings unless something is just plain wrong with the WB
    What is the formula that you are using?
    Save/post the transform that you're using for the WB
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    2007 Escalade, A6
    Stock
