Results 1 to 3 of 3
Thread: Suggestions on emissions tuning
    Aug 2008
    17
    I have my MAF tuned in line with my MAP and WOT tuned on a dyno with wideband to a nice 12.7 across the board.
    My O2 sensors were just off the wideband by a few points ie running 14.5 to 15 on cruise while I'm commanding a 14.6 AFR in HP Tuners. I have cats on the car so I would guess that I'm running either close or to what I'm commanding or a bit richer.
    My question is what should I focus on to get the car to pass emissions? We do an idle test and a drive test that is 1800-2500 rpm.
    Cam is a TR224 0.561 lift, 112 LSA. Longtube headers, ceramic coated, cats, true duals, stock 98 LS1 heads, LS6 intake and Air Lid.
    It is a bit rich at idle according to HP tuners, I've played with leaning it up in the primary VE and raising timing a bit, but I think something else is richening it up there. Any suggestions on how to proceed?
    Tuner radkon's Avatar
    May 2007
    Cleveland, Oh
    62
    Its gonna be tough if they sniff it. The TR224 114 can pass but the tune has to be pretty dead on for a 112 to pass. Start with the VE table and get it perfect. Then double check the MAF and watch your AFR. Keep it as close to 14.681 as possible and pray. Good luck
    2004 Yellow M6
    HPT Pro, LM1, SVEDE, 85mm FAST Manifold, 85mm TB, TR224 112 Cam, TEA ported/milled 243 heads, SW LT headers, SW Custom Side Exhaust, King springs, Pedders shocks, Hotchkis sways, Pedders & ES Bushings, DBA rotors, Hawk/Axxis pads, Stoptech lines, shiftlight, AP Sideskirts, AP rear bumper, 05 hood, SAP grilles, Hoens, dual aeroforce gauges
    Stock 309.8 RWHP 330.7 RWTQ
    Now ? RWHP ? RWTQ
    1 of 1014
    2017 Audi A5 2.0T Cabriolet (bone stock) Daily/winter driver
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    Are you CL? If so, then the o2s are going to correct back unless you change the swtich points. Also, be careful with timing, that will play a large role in it being emissions legal or not.
    Sulski Performance Tuning
