Results 1 to 8 of 8
Thread: Moving pids around in table display?
    Aug 2007
    503
    Is it possible to allow the user to move pids around in the table display? Seems like you have to delete them first then add them if you want to do any kind of sorting.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,287
    yeah they need to be deleted & then added theres currently no way to just move the around or cut & paste.
    Advanced Tuner CRASHNBURN's Avatar
    Jun 2007
    Mn
    240
    A sort like excels has would be awesome for the table viewing...
    It would also be nice to make the gauges running horizontal also.
    2006 LBZ Duramax 4x4 CC SB 2500HD SRW 4x4 LT1 (with extras), Blocked & Fingered, Fumoto drain valve, Keystone Ram Air Good Hood, Banks Ram Air, Access cover & Rhino over the rails, Victory Red.
    33'-0" Dutchman fifthwheel,Tekonsha Voyager Brake Controller
    Banks Sixgun with HPTUNERS.
    Dec 2005
    NV
    190
    I would also like to see this. I hate deleting and adding pids just to move them
    2000 EC, SB Z71 03 LQ4, 05 front clip with e-fans, STS turbo, GT67, Blow off valve, 170Kpa, Alkycontrol, 44lbs injectors @ 100% dutycycle, Comp 918's, HPtuner, 02 ECM, Dyno Jet Wideband, Eaton LSD, Speed Engineering 4l80e conversion, 2800 ART CARR stall removed now running stocker . 11.87 @ 114
    New times 11.41 @ 119.. look out 10's here I come.....
    Oct 2004
    Orlando FL
    766
    Ditto. AutoTAP for DOS v1 had the ability to move PID's around without deleting/adding.
    1998 NBM Camaro Z28
    LS3 motor
    Mod list
    +1 for the move PID's around without deleting/adding ...
    HP Tuners Support
    (foff667)
    28,287
    Quote Originally Posted by JimMueller
    Comparing our scanner to autotap dos really hurts, while this is a good convenience feature it is very low priority as it has little real functionality for anyone named anything other than Monk
    Quote Originally Posted by Bill@HPTuners
    Well some of us might actually watch that display when viewing a log. I realise that there are other ways but sometimes it is nice to just look at the numbers and one that seems out of place really stands out. Problem is that you then want them grouped. Think of it as gauges for the none visual in the crowd.
    Oh and some of us are just OCD too
