Page 31 of 57 FirstFirst ... 2127282930313233343541 ... LastLast
Results 601 to 620 of 1139
Thread: Dodge Progress
  1. #601
    Senior Tuner ElecTech's Avatar
    Feb 2006
    Charleston, SC
    1,385
    Quote Originally Posted by Hemituner View Post
    If you think that snippet was easy to come by and run thru IDA you have to learn alot.
    No one said easy. I'm well aware of the complexity of something like that which is why I choose not to dabble in it, but my original statement still applies.
    If NGC3 is done where is it??
    you must not have been paying attention if you are asking this.
    Jaime
  2. #602
    May 2005
    Los Angeles
    131
    I offered once to help for free a couple years ago..
    never heard a thing back.
    NGC3 died in 2006 it's like NGC4++ now.
    The snippet I provided is NGC4 with NAG1 TCM support.
    Not trying to smear or push anything I'm just trying to push a manufacturer in this case HP.....
    but not to worry I'm equal opportunity
    I slam Diablo too and they had all the Hemi files hand delivered to them thats why they are so far along.
    BTW JTEC is sooooooo 2000
    OK I'm done and out.
    Back to your regularly yearly scheduled begging.
    BTW I didn't start this thread....... HP did 2 1/2 yrs ago....
    How is this helping anyone or "pushing them" , I don't see you saying anything constructive or helpful, just a bunch of ego stroking on your part.
  3. #603
    HP Tuners Owner Chris@HPTuners's Avatar
    Mar 2003
    Melbourne, Australia
    5,328
    if we were in the business of removing chips and reflashing them with EEPROM flashers we could support the EGS52/53 no problem there is a reason why nobody supports OBD2 flashing of this TCM but i assume you already know that.
    I'm just nailing down some final issues with my 300C supercharger install and once that's done beta will begin. I want to make sure we have everything required for NA and FI tuning.
    I know it's frustrating, but the majority of our problems getting 2.24 released over the last 3 months have been 3rd party software vendor bugs breaking our development environment.
    Chris...
    I count sheep in hex...
  4. #604
    Advanced Tuner jakebdb56's Avatar
    Oct 2006
    Houston, TX
    644
    Just a quick question on the side that you mentioned FI. Do you think there will be custom boost OS's for the HEMI's?
    '12 Duramax - Tow Rig
    '90 S10 - Alleged "Race Truck"
  5. #605
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    24,045
    Quote Originally Posted by jakebdb56 View Post
    Dodge's likely don't need it, the VE table normalizers are adjustable as are most other normalizers on dodge.
  6. #606
    Mar 2003
    5,328
    i hope not, DCX stuff is all speed density and most of the GM stuff we did was to remove the MAF and allow MAP sensors bigger range. So far i haven't seen a need, but my 300C is running 8 PSI. MAP should easily go to 250 kpa and maybe higher using the std OS.
  7. #607
    Feb 2006
    Charleston, SC
    1,385
    Quote Originally Posted by Chris@HPTuners View Post
    I would say the only real need would be increasing the VE table size or adding a supplemental boost table to allow you to keep better resolution in the part throttle areas for calibrations running over 2 bar. The normalizers are great, but you are still limited in resolution by the table size. Other than that little detail, the NGC's are very boost friendly.
    Jaime
  8. #608
    HP Tuners Support
    (foff667)
    24,045
    Quote Originally Posted by ElecTech View Post
    Yeah I don't see a custom os for that happening...for GM's we did them out of necessity since the pcm has a hardcoded maf limit and the normalizers aren't adjustable.
    From the looks of it the NGC3 VE table is 17x17 meaning for 210 kpa you are getting increments of 12-13kpa which in our LS1 gm custom os's we get 10kpa increments in 1/2 of the years so its pretty similar.
    -Bill
  9. #609
    Feb 2006
    Charleston, SC
    1,385
    -Bill
    Agreed, definately not worth the time, development wise. Its really only over the 2 bar line when things start getting tight.
    Jaime
  10. #610
    Oct 2006
    Houston, TX
    644
    Ah ok that's cool. I'm looking forward to being able to look at the files and learn more about them. Thanks for the reply
  11. #611
    Mar 2003
    5,328
    also the axis values don't have to be linear, you can still get good part throttle resolution and then sacrifice resolution on boost, you rarely need much resolution between 100 kpa and full boost anyway
  12. #612
    Oct 2006
    Houston, TX
    644
    I just got to looking around on that and I'm pretty excited to start playing around with the normalizer values on a customer's turbo truck.
  13. #613
    May 2005
    Los Angeles
    131
    Chris, have you had success getting your car into OL power enrichment, without invoking wot through lowering the wot pedel threshold constant? This is enough of a problem in the Hemi community that some people are resorting to using piggyback O2 sensor signal conditioners to help bias the fuel trims so there can be some enrichment under part throttle boost situations . Either that, or run closed loop at stoich under boost
  14. #614
    Mar 2003
    5,328
    Quote Originally Posted by hexdummy View Post
    i'm looking into it, i am seeing the throttle issue and hopefully will solve it
  15. #615
    Oct 2006
    2
    My maggie for my jeep arrives on monday with some hypertech programer crap with it, please hurry.
  16. #616
    Dec 2010
    NY
    2
    Name Change
    Will NGC3 have EGS52 support?
    Please refrain from using my Name. It is currently trademarked and I would appreciate your understanding in the matter
    A.J. Berge
  17. #617
    Dec 2005
    Sydney Australia
    509
    ford turbo 6's run up to 5psi boost at stoich in the factory tune, dosent seem to hurt them at all..
  18. #618
    May 2005
    Los Angeles
    131
    Quote Originally Posted by VYSSLS1 View Post
    Sure, most late model engines will run at closed loop under high load conditions for a while, but there is logic in the controller that will at some point richen the mixture based on temperature limits of the exhaust, catalyst, and other components. Manufactures carefully test engine packages to know what these limits are, and run at these limits to reduce emissions and maximize fuel economy.Certain VW/Audi cars I've worked on use physical egts to measure and adjust fueling rather than calculating the temps . When you install a turbo or supercharger on a car that was never calibrated for forced induction in the first place, the temperature models that were set up by the manufacture are no longer accurate, and likely will not take into account the additional heat load. If there was an effective way to calibrate the exhaust/catalyst enrichment tables for us in the aftermarket, then I suppose that could be a reasonable solution to get power enrichment without going to wot. I don't except the idea that just because we see factory cars running closed loop under certain high load situations, for limited amounts of time, that it's ok for us to run closed loop boost.
    - Chris
  19. #619
    Feb 2005
    30
    Is it possible to tune NGC3 computers with HP tuners if you want to use the beta software?
  20. #620
    HP Tuners Support
    (foff667)
    24,045
    Quote Originally Posted by 94SS View Post
    Not currently, the hardware firmware update isn't automated yet. Without the new firmware you won't be able to read or write to them.
