Page 28 of 57 FirstFirst ... 1824252627282930313238 ... LastLast
Results 541 to 560 of 1139
Thread: Dodge Progress
  1. #541
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,298
    Quote Originally Posted by BlackZJ View Post
    except it uses the ISO-Protocol...
    Correct, ISO & the older ford protocol(I can't recall the name off the top of my head) require the new firmware. I've been able to scan an ngc4 charger and I know it works on ngc3 hemi's, not sure what dodges use the ISO protocol off the top of my head but I have a list around here somewhere.
  2. #542
    HP Tuners Support
    (foff667)
    28,298
    Ok the list I have only shows up to 98 on chrysler's and shows iso up till then.
    If anyone has any info after 98 though let me know and I'll add it to my spreadsheet.
  3. #543
    May 2005
    Los Angeles
    161
    From my earlier post:
    Quote Originally Posted by hexdummy View Post
    The later JTEC+ ecus switched from ISO 9141 (sharing pin 7 with SCI in the OBD2 connector) to PCI or better known as J1850 VPW (running and terminating into a previously unused pin 2 in the OBD2 connector.) It varies depending on model, but if pin two is populated, I imagine it should work. I have only used it on GEN3 Vipers, but going through the different year/model OBD2 pinouts, they started wiring to pin 2 in 2001 .
    - Chris
  4. #544
    HP Tuners Support
    (foff667)
    28,298
    J1850 is the same as the earlier fords so yeah that one we don't support yet either at this current time.
  5. #545
    J1850 for Dodge is actually VPW same as GM. The EEC based Fords use PWM.
    In any case if your Dodge PCM uses VPW (some JTECs) or CAN (many NGC3) you should be able to scan it with existing firmware, for SCI & ISO you will need the new firmware.
    I count sheep in hex...
  6. #546
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by Chris@HPTuners View Post
    In any case if your Dodge PCM uses VPW (some JTECs) or CAN (many NGC3) you should be able to scan it with existing firmware.
    Working fine on the NGC4's, as well. Just wish we had the enhanced PID's loaded for those. You've got me spoiled on the enhanced PIDs for the NGC3 already.
    Jaime
  7. #547
    Jan 2009
    Spokane, WA
    480
    New firmware? For the interface, right? Does this new firmware just give a broader range of vehicles that it can see? Or will it limit use on a certain model/age?
  8. #548
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by waynehartwig View Post
    Should allow scanning SAE required PID's on most OBD II compliant autos using the SCI or ISO communication protocol. Plus allow for the reading/writing of future supported platforms.
    Jaime
  9. #549
    Jan 2009
    Spokane, WA
    480
    Quote Originally Posted by ElecTech View Post
    Ok, got that part. But 1- how do you know if you need it (what version you have) and 2- how do you update it? Where is the updater/file?
    When I did a search, it almost sounds like it is automatic when you connect to your device through the scanning software?
  10. #550
    Feb 2006
    South Carolina
    1,525
    The firmware update isn't released yet. When it is, it will be bundled with the software update and should start automatically once you plug you interface into the computer.
    That's how the last one worked.
    Jaime
  11. #551
    Sep 2010
    Alpena, MI
    186
    Can't wait to edit my tranmission software!!!
  12. #552
    Oct 2010
    11
    So how can a Beta version of this software for NGC3??
  13. #553
    Hey Chris or Bill
    We need you guys to find the trans temp PID and allow it to be added to the scanner software. It is a necessity when doing a converter swap/trans swap, or even checking fluid levels because you check it at operating temps with a metered dipstick by temperature.
    The only thing I have found so far that reads that PID is a starscan, they are nice to have but uber expensive.
    If you could map that PID and add it I would be grateful. PS, I tried to add it on the latest beta yesterday and no dice.
  14. #554
    Dec 2004
    for now, Kandahar Afghanistan
    39
    Well its been a long long time since posting on HPT. So glad to see this business is still top notch.
    Now onto my question: Where do we stand on getting the VCM Suite for LX platform 05'+ Magnum, Charger and 300s in the V-6 or Hemi models? I emailed in August and got a speedy response that it was being worked, but thought I'd pop in here and ask for update. Thanks.
    Charlie
    00 NBM Z28 Rossler A3 ATI 4k TC, 347 w/ ETP 225's, EDC 231/242 .637/.622 @ 114*, LS6 Intake, Kooks 1 7/8" LTs, Wolfe 6pt, BADZ LCA, Spohn SFC & TA, Custom 2 Stage N2O. Next up, 90/90, 9" and Bogarts.
  15. #555
    HP Tuners Support
    (foff667)
    28,298
    pretty good, we have a couple of customers that have been able to successfully read these pcm's using the current public beta + beta firmware and the scanner is essentially done for them. Not too much longer.
  16. #556
    Advanced Tuner jakebdb56's Avatar
    Oct 2006
    Houston, TX
    646
    Sounds optimistic
    Any idea on a licensing structure yet?
    '20 AT4
    '01 Suburban 2500 Dad Wagon
  17. #557
    Tuner BlackZJ's Avatar
    Apr 2008
    German speaking part of Switzerland
    159
    How can I update the Firmware? Or if it's an automatic process, how do I know that my Interface has been updated?
    Is the beta firmware also a public beta?
    - Mat
    '97 Jeep Grand Cherokee ZJ, 5.2L (Canada Import), 2" Lift
    (CAI, Modded Kegger, Ported TB, 3" Cat-Back, SCT Custom Tune)
    '98 Jeep Grand Cherokee Limited ZG, 5.9 V8, Stock
    '03 Skoda Fabia, 1.4L 16v
    '98 Chevrolet Camaro V6, 3.8L, Targa, ZZP GT1 Cam, Dynomax Cat-Back [sold]
  18. #558
    HP Tuners Support
    (foff667)
    28,298
    - Mat
    Its being done manually right now on a VERY limited case by case basis(ie don't email us) Its not in public beta.
  19. #559
    I'm having a heck of a time nailing down this really rowdy cam in an 09 srt8. Is the histogram function working in the beta scanner so I can make an afr error histo and try to pin this thing down??
  20. #560
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by TurboTBSS View Post
    The histograms work for any vehicle that can be scanned (always has). You just have to construct them yourself. For the 09 you will also need to create a User Defined PID for Pressure Ratio as the SAE PID's don't include it.
    Jaime
