am in need of some tuning help. I just installed my new 96lb. injectors and AEM driver box. I put in a generic IFR table and scaled a few things back in the injector tables. I am running a boost referenced return style fuel system and I turned the base pressure down to 42psi from 58 with my old 60lb.ers. I finally got the car cranked up yesterday and I am still having too much fuel at idle almost to the point where it burns your eyes just sitting in the car. I don't know if it is pertinent or not, but I also changed the car over from a manual to an auto at the same time I did the injectors. My other problem is the LC1 I have seem to has something wrong with it where it will work sometimes and then it will just randomly peg at 14.9 so I can't say what my actual idle afr's are at. To fix this problem I ordered a PLX wideband and I will be swapping it in later this week. Could you look at my tune and maybe make a few changes here and there to get me going or if you have any suggestions I can try....
