Results 1 to 10 of 10
Thread: 6 Speed Allison tuning
    Jul 2008
    11
    Can HPTuners read and flash the entire 2MB flash in the 6 speed TCM?
    While on what can be done, do you give access to the shift tables for "Default mode"?
    Jul 2008
    11
    Anyone at HPT know the answer?
    Apr 2003
    Almost 2000 feet.
    7,876
    TCM only? No.
    Always Support Our Troops!
    Quote Originally Posted by Cougar281
    in theory yes we can, but we don't. It takes around 45mins to completely read the TCM. So we just read and write the cal only.
    I count sheep in hex...
    Jul 2008
    11
    Quote Originally Posted by Chris@HPTuners
    So if for some reason someone wanted to spend the 45 minutes to read the TCM, would it be possible to arrange it? As for flashing, if the cal write speed is any indication, an entire write should be about 7 minutes.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,279
    Not currently.
    Advanced Tuner CRASHNBURN's Avatar
    Jun 2007
    Mn
    240
    What would you want to wait the 45 min for? Just curious. What advantage would this give you???
    2006 LBZ Duramax 4x4 CC SB 2500HD SRW 4x4 LT1 (with extras), Blocked & Fingered, Fumoto drain valve, Keystone Ram Air Good Hood, Banks Ram Air, Access cover & Rhino over the rails, Victory Red.
    33'-0" Dutchman fifthwheel,Tekonsha Voyager Brake Controller
    Banks Sixgun with HPTUNERS.
    Jul 2008
    11
    Quote Originally Posted by CRASHNBURN
    Well, Assuming both full read and write where possible, one reason would be if one had an 07 (classic) Duramax/6speed and wanted to turn off adaptive upshifts or adaptive downshifts. AFAIK, those options exist in the 06 tunes, but not in the 07. If you could full read an 06 TCM, then full flash that tune into the 07, you could then disable the adaptive up/downshift.
    Jun 2007
    Mn
    240
    Thanks for explaining .You learn something new everyday..
    Is that because Gm updated the tcm then? I always thought the 06 & 07 classics were the same.
    HP Tuners Support
    (foff667)
    28,279
    The problem with many of the late model pcm's & tcm's is if the bootloaders don't match you could end up with a brick on your hands making write entires more harmful then anything for the most part. This is why we don't offer write entires for some applications & don't recommend ever doing one unless absolutely necessary.
