Quick Help with setting up NGK AFX Wideband O2
OK I am trying to set up a NGK WB O2 sensor using the EIO preset. 1st I have inserted it in to the Primary table under EIO input #1. Then when I try to add it in to the graph I select it into on of the charts as I would any other item I want to graph. When I click the save button on the chart it says it is not available. However on the primary table it shows the AFR correctly along with all the other items I am recording. It just will not let me graph it. I know I am probably missing a setup step somewhere I am just lost. Anybody know where I went wrong???
Thanks,
Joe
Nevermind I got it! I hate it when you look and look and can't figure it out then you post the question and you figure it out 2 seconds later.
