Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Thread: Can't enable EGR for Wideband
    28,266
    The later LS1 pcm's don't have enough room for the additional tables, since egr is already disabled in the later operating systems it was deemed expendable so we used that space to add our os mods, so its either 1,2 and 3 bar support or being able to log a wideband through EGR, we chose to add custom operating system support.
    Feb 2006
    central michigan
    349
    since only some trucks came with a transmission temp gauge,but the sender was in all transmissions,those pins on the pcm could most likely be used.you'll have to check your wiring pinout.
    Advanced Tuner Atomic's Avatar
    Jun 2008
    455
    I think I found a solution. I put the fuel tank level sensor (instead of EGR) on a switch with my wideband on the other end. Only difference is now I just have to remember to flip the switch before logging and know I have enough fuel before hand. I really didnt want to mess with the AC system since it gets pretty hot here down south.
    Jun 2008
    455
    I couldnt get it to work correctly using the fuel level sensor so I went to the AC pressure instead, seems to work ok.
    Dec 2009
    30
    Not meant to hijack.. I have a 98 fbody a4 ecu, it apperas to be in 2 bar map mode, do we NEED to add egr voltage to the table view in order to log EGR (wideband afr) ?
    Mine says "24" then "this vehicle only supports 24 bit operations" or something along those lines...what is up with that?
    Is this the HPtuners taking up all the left over space on the ecu for mods? Can I somehow get rid of the 2 bar programming? I'd really apprecaite if I could datalog properly wide wideband!
  6. #26
    May 2021
    48
    I know this is an old thread but I just stumbled across this after wiring my wideband to work through the egr. The car is a 99 fbody p01 controller. Am I understanding this correctly, there's no way to enable the egr so the wideband will function?
  7. #27
    I have a 2002 that should have the same PCM as the 1999.
    EGR is not used on the 2002 Camaro's, but the EGR pin 55 on the blue PCM can be used as an analogue input for the wideband.
    When I set mine up, if I recall correctly, originally it did not receive the WB signal until I enabled the EGR and zero'd the table.
    There are basically two math formulas for converting the AEM WB from volts to AFR, depending which vintage gauge you have.
  8. #28
    Oct 2008
    Mebane NC
    475
    post the tune. depending on the OS you may be able to use other pins.
  9. #29
    May 2021
    48
    FT7.9.6 less TC plus egr enable.hpt
    This is the tune. I just don't see a way to enable the function.
  10. #30
    Oct 2008
    Mebane NC
    475
    Go to the exhaust tab, under General enabled, change from Disabled to Enabled. EGR Tab.jpg
  11. #31
    May 2021
    48
    Yeah it's not there on mine. Can it be segment swapped? I'm pretty green on how those work.
  12. #32
    Oct 2008
    Mebane NC
    475
    Go to system, General tab. Open systems Options. What file are you starting with?
  13. #33
    Advanced Tuner Matt Vardaman's Avatar
    Mar 2021
    207
    Quote Originally Posted by kyotey1693 View Post
    They took away the ability to turn on/off egr with later updates of hptuners. If you go back to using the version of hptuners that came with the mpvi2 on the flashdrive, the button will be there again. I had two different versions on my computer and found that out. Post your file and I'll change it for you and send it back. You still won't be able to see the button though, unless you get an older version.
    2001 Silverado 5.3 - 209/217 cam, GT45 Turbo on 7lbs, Aem x-series wideband, 50lb/hr flex fuel injectors, on E85 with content sensor
    1999 Silverado 6.0/4L80E Summit Stage one camshaft, 317 heads (replaced cast iron)
  14. #34
    Oct 2008
    Mebane NC
    475
    Interesting, I'm still using 4.10.7.
  15. #35
    May 2021
    48
    Thanks man! I had no idea that would work.
    FT8 with RTT 1 BAR SD OS.hpt
  16. #36
    Aug 2020
    8
    SDStep1.hpt
    Hello, are you able to enable my egr in my tune file as well so I can use my wideband o2 to log, thank you!
  17. #37
    Quote Originally Posted by xsocaltrashx View Post
    SDStep1.hpt
    Try this. Not 100% sure I got it right.SDStep1_egr enable.hpt
  18. #38
    Dec 2020
    Dallas, TX
    5
    Quote Originally Posted by gametech View Post
    I am running 3 bar Speed Density tune and after wiring into Pin 55 Blue I cant see the Voltage. Like the others I can not Enable EGR?
    virgin.hpt
  19. #39
    Try this. No guarantees.
  20. #40
    Dec 2020
    Dallas, TX
    5
    Thanks, I actually remembered that I had a 2020 HPTuners thumb drive and deleted the new software and installed the 4.7.8 version. EGR Enable/Disable button re appeared ha. So thats the hack to fix the issue.
