I have a 2008 CCSB VMax 4x4
Just wondering if anyone has done much tuning with Max Package trucks.
I have removed the 4 second PE delay which seemed to wake the truck up a bunch.
I removed the speed limiter and have set it to use the tune calibration instead of from GMLAN.
I have not changed the Torque mgmt yet. Any recommandations based on the 4L70E which is reported to be in the trucks?
I've been mostly focused lately with working on the mileage. I've move the TPS max to 20% to allow you to actually give the car some throttle but keep DoD active. But the vacuum seems to be most critical for AFM.
I think the biggest area that needs work is the Dod enable/disable Vac tables. Mine have been modified, but I have not had time to fine tune them. Has anyone had time to log them and see what seems to be optimal? The truck is holding DoD mode longer, but I think with some more tune time it will hold much better and off course mileage will go up. And these days every gallon counts. So I wanted to see if anyone else had done any logging or had any data. I have heard of some tuned 4x4 truck running 22mpg, and 2wd running 24.
I have not leaned the truck out or jacked up the timing since I am pretty much going to run 87 octane exclusively. I know these trucks can benefit from some timing. So, has anyone found what the trucks seem to be happy with?
I can log all the data, and play with the tune myself, I jsut figured it never hurts to ask. If no one posts up, I will post results as I have time to mess with it.
