I wired it up per the VCM help. I added the WB LC1 PID and when I crank the car up it appears to read right for a little while at idle and then for some reason shows super lean and stays there..
This is a 99 C5 with a 3 bar MAP sensor.
Most likely you will need to go to a user defined PID for your wide band. If you search this forum you will find lots of info on how to do that. You will also need to program the outputs of your wide band.
Did a search and tried them all. They did not work due to the LC-1 having issues... Time to RMA it as well. Thanks for all the looks guys..Originally Posted by bigbrian442
