Read Below and the attachment. I would like to hear what anyone has to say about this dudes theory
He States.....
"From Physics to Speed Density
Doubt is not a pleasant condition, but certainty is absurd. (Voltaire)
Eventually I got tired of working off AFR % Error and Fuel Trims, and figured out that there’s got to be a better way of arriving at the final fueling. Also, once I found out that the VE in HPT/EFILive is not a real VE but some combo package of mass, pressure and temperature, I decided that’s a moving target. Combine the two, and you got an error prone method of aiming at a moving target—I have no idea frankly how we got any of our tunes working right this way."
"So all this stuff got me thinking: If Volumetric Efficiency is constant then the air moving through it should be calculated dynamically according to the conditions. Of course, our VE (from now I’ll refer to it as the GMVE) contains pressure and temperature. Thus, what I figured I needed is a way to convert from a fully tuned GMVE table obtained using historical methods, to a true mechanical, absolute VE. Knowing that, we can calculate back to GMVE, adjusting for any conditions we’d like! No more retunes. No more waiting for fuel trims to catch up. No more worrying about racing in the desert or mountains and suffering from a double penalty of bad air and a bad tune. Just start with your absolute VE, punch in fresh weather data, and out comes your ‘here and now’ GMVE table ready to flash."
Article is the attachment
