Results 1 to 3 of 3
Thread: custom vol on out .0 not .00 and trble with FJO
    May 2004
    FWB Fl
    299
    I'm having problems with my boost/vac gauge the out put is suppose to be say 2.35v and HPT changes it to 2.40 and it make myreading way way off....
    also is there any way to adjust the FJO thing in HPT to offset voltage? if not i'm having the same issue as above programming hte FJO .5-4.5 output....
    and if i use the liner output it tries to use 0-5 volt and not .5 to 4.5
    help
    http://www.turbov6camaro.com
    1997 Stalled V6 Camaro
    Goal: 10.99 in the 1/4
    Goal: 100 MPH (completed)
    Best Dyno: 456 RWHP and 509 RWTQ
    Best: 1/4 mile 11.23 20 PSI
    Best1/8: 7.18 @ 99 1.83, 60 foot 20 PSI
    May 2004
    FWB Fl
    299
    Ttt
    May 2004
    FWB Fl
    299
    Okay use volt/.4+8.75 and it should work fine...... only took me a year to figure it out but there it is
    Kieght may want to add this to list to add ? (this is for the FJO .50 to 4.5 out put
    some version of the FJO don't let you loginto the to custom the voltage out put
