I'm having problems with my boost/vac gauge the out put is suppose to be say 2.35v and HPT changes it to 2.40 and it make myreading way way off....
also is there any way to adjust the FJO thing in HPT to offset voltage? if not i'm having the same issue as above programming hte FJO .5-4.5 output....
and if i use the liner output it tries to use 0-5 volt and not .5 to 4.5
help
