Ok the first problem It says I have no power?? it found the interface but no power??
My other question How do I find the device manager to check if I have
both A and B????
Mike
both A and B????
Mike
2007 C6 coupe LS3 416 6 speed mn Z51 3LT
Vararam Snake charmer 160 Stat
Kooks 1 7/8 headers with jet hot
Fast 102 ported intake 102 TB RPM Level 5 T56
MGW short throw ZIP 4.10 Severe Duty rear
RPS TWIN DISC CARBON CLUTCH CCWs ele wp
RPM LEVEL 5 TRANS W/HARDENED OUTSHAFT
http://www.youtube.com/watch?v=PtOPy_lp2QY
10.66 1.47 60ft 133+mph
I found the device manager I have both A and B still no POWER???????????????
Mike
check your cigarette lighter/ALDL fuse
oh its hot!
Mike
so the fuse is good?
Im stumped??
Bad unit???? This was the error message I keep getting.
(The interface was found but no vehicle power was detected
Verify cable is connected and key is in the run position also make sure diagnostics port has power and its fuse is good)
Mike
verify that everything is plugged in, and verify that there is power at the ALDL. you can do that by plugging in the HPTUNERS box into the port of the car and not plugged into the computer. if the light lights up on the box there should be power there
Thanks Ill try it right now
Mike
Thanks no power to the car just like it said
Witch fuse is it?? and why would it blow???
Mike
who knows why it would blow. some vehicles it happens fairly often (like my dads 05 2500) some it doesnt (like my 2007 1500). you will have to find the fuse, probably under the hood. look for cigarette lighter or accessory or ALDL or somethign of the like
Im looking now thanks again so much I owe you
Mike
Check on the floorboard on the passengers side There's a bunch of fuses there as well - Usually it's the cig lighter fuse or one with DLC or ALDL marked on it.
Always Support Our Troops!
Is there another Group of fuses under the dash??
The box under the hood didnt have the one I was looking for
I removed almost all of them. What size do you think it would be??
20amp??
Mike
15A maybe 20A. check under the dash
I checked under the carpet on the pass side they look good????
Mike
you need to find the right fuse and replace it. it wouldnt be the first time that a fuse went out without being visably blown. find the proper fuse and replace it?
Boy that sounds easy LOL
I gotta laugh or im gonna cry LOL
Mike
Is there any other spot on the 07 for fuses???
Mike
one inside fuse block and one under the hood.
open up your service manual and see if they tell you anything in the trouble shooting section. or you can call your local dealer and have them tell you where the fuse is located. im sure most of the techs know off the top of their head
pg 421-423 of your service manual has a picture. it should be labeled LTR on the inside fuse block
This link may help.
http://forums.corvetteforum.com/show...highlight=fuse
