screenshot attached. Please email support and they will advise when new beta is available.
Chris...
I count sheep in hex...
yeah they might be ready by the weekend. i already had 95% of the work done so just a couple of hrs and it should be finished.
Hopefully these are the ones
I've emailed everyone that has contacted support as we've posted the new beta with these additional parameters.
No clue
i do have one quick question. do you guy recommend rereading the VCM with the beta editor? or is all the info already in our current HPT files? i've done it both ways in the past, just wondering what you think.
The info is already in your current hpt files.
If he has an understanding of how the tables work Im sure he'll chime in, but as you've probably noticed nothing with these transmissions is easy to understand and not any easier to try to explain
I understand that but like before, we at least need to have some idea of what values to use especially for something as important as TM.
Looking at the Shift Torque Factor values, given that the default value is 1.0 but allows for a range of -32 to +32, what values would represent 50%, 75% or anything else in the range of 0-100%?
i think it would be like if you change it the 1-2 factor to .5 from 1 (because 1 multiply by any number is the original number. at .5 it would be half). the trans would be reading half the shift torque which might change the way timing is pulled. I don't know, just a theory. ill be messing with it in the next few hours.
