Yeah well all I can say is I've been driving around now for nearly 2 days with the "Max Adapt Volume" table set at 200 across the board and the difference is black and white. My trans has never shifted like it has in the last few days!
If the trans is using the same clutch for different shifts like mentioned above then I'm even more confident that I'm not asking too much of the trans. If it's using the same clutch for the 4-5 shift and that was set at 200 then there should be nothing wrong with setting the 2-3 shift at 200 too??
So far so good anyway. I'm also playing around with the torque management when the trans is cold. I find that the pause hesitation on the downshifts (when the trans commands zero torque because the box hasn't completed the downshifts) as part of the Torque Management isn't commanding for long enough. As a result the trans finishes the "Zero Torque" command too quickly and the box still hasn't finished the downshifts. ONLY HAPPENS WHEN TRANS IS COLD. NOT AN ISSUE AT ALL WHEN TRANS IS WARM TO OPERATING TEMPERATURE.
I'll let you know how I go with that if there's anyone interested who appears to be having the same issues.
