After installing the new 2.x version of HP tuners on my vista laptop, i cant seem to get the LC-1 to read properly, it constantly reads 21.4 what is going on?
98 TransAm WS9 Raim Air – Stage 4 4L60E Trans -3:90 Rear -1.8 HS Rockers - Full UMI Suspension – 85MM Lid – 85MM Z06 MAF - LS6 Z06 Intake - 224/230 Comp Cam - 7.350 Push Rods - 243 TEA Stage 2 LS6 Heads 61cc - Melling 10296 Oil Pump - Caddy Race Lifters - SLP Underdrive Pulley - 160 Thermo - 42# Green Top Injectors - HPT - SLP Line lock - Pacesetter LTube Headers - Yank SS4000 - 98 to 2002 PCM Swap www.mrk-motorsports.com
It may have reset how you have the voltage settings set up...the custom inputs? eg. Like 0v = 10 a/f and 5v =18 a/f or are you using the ones already input into hp tuners?
I have always just used all the default values in HP tuners
Did you try reprogramming the LC1 to see if the a/f value it was showing changed. Here's a good thread on how to check for voltage offsets.
http://www.hptuners.com/forum/showthread.php?t=11018
I believe it show's how to read raw voltage. Not sure on that though. Try changing a few things to see if it makes a difference. Do you have a gauge hooked up to your lc1?
I will give that a try. I do see they have a new firmware available on their site since my purchase and install.
The LC-1 is hooked up withthe brown wire to my HP Pro device. It worked in the fall last year perfectly.
New Laptop Vista and the new Hp Tuners it stopped. working.
When the car was in storage over the winter the battery was disconnected. Do you think that erased the programming of the LC-1?
could have, the LC1 is junk. I would bet it is something with that and not HPT as everyone would have seen that issue on here if it was HPT related.
Sulski Performance Tuning
What is the best or Favorite wideband now?
Have you loaded LogWorks? You should do that so you can verify that the problem is or isn't with the LC-1 controller/sensor and flash the controller with a fresh config.
Bill Winters
Out of the LSx tuning game
I just have never had (nor heard of) anyone having good luck over a period of time with the LC1.
Strange. The LC-1 had a firmware of 1.00a in it. I updated it the new the Firmware of 1.10 and it work perfectly now....Strange.
Check for your VCM Suite config files in C:\Program Files\HP Tuners\VCM Suite 2
License.dat
VCM Editor.cfg
VCM Scanner.cfg
VCM Suite.cfg
And move them to: My Documents: then HP Tuners\Settings
Always Support Our Troops!
