VCM changes needed after Camshaft Replacement for Corvette C6 6liter
Hello,
Would you please tell me what parameters needs to be changed in VCM after replacing the standard camshaft with a camshaft with following specs:
Duration Lift Lobe
Separation
Intake Exhaust Intake Exhaust
224 220 .581 .581 116
Best Regards,
The only things that will need to be done is VE and MAF tune against STFT's or LTFTs or via wideband.
That being said, a lot of timing changes can be made to correct choppy idle and hot start issues, as well as torque limit settings in engine TM.
