Speedomter is not working for some reason and I have an appointment to have it tuned. Would it not working affect anything?
If the speedo isn't working the ECM may remain on the idle tables. That isn't good for tuning. Are you seeing MPH in the scan logs or just no speedo on the dash? If you have MPH reported in the scan logs you're ok.
Always Support Our Troops!
Would the trans showing neutral (a4 to m6 conversion)have anything to do with it ?
found the problem.
Originally Posted by v8s10s
What was it?
pin backed out .
