I logged the car for the first time in a long time (on a new motor) and airmass seems very low. I cannot find any old logs to compare to and wanted some opinions. The log file is attached. It is an 02 LS1/T56, boltons, trex cam. The wideband is showing about 1-1.2 points leaner than it really is (yes, fueling definitely needs adjusted, this was the first run of the new motor and just getting logs). The tune is OL SD, stock injectors, fuel pressure at about 62psi falling to about 58psi WOT.
Thoughts?
