I've been playing with my VE table for around a month now, getting familiar with the hand smoothing process and what not, and i was told in another thread to make the following adjustments to the HPT fie: (Currently tunning in OLSD)
Set PE Delay RPM to 0,
Set PE enable RPM to 0
Set PE Enrichment Rate to 2
what's the idea behind this values, and would i screw my current VE doing so?
I've also read about halving the Burst Knock Retard table (Base vs Cyclair Delta), should i halve all the values, or just the V8 mode one ?
