Okay, I have Russ' Idle Config. downloaded. Did that a few months ago. My question is: how do you get all three in line? I would imagine that each one would affect the others. Which do you do first? If I had to guess, I would say: get the IAC down where it needs to be, get the idle spark set a little less than most vacuum, then run the airflow config. to get that squared away. Is this correct? Thanks for any help.
