I assumed that the staff had more important things to do than respond to my feature request for the ability to filter out transient states in the data for VE tuning, so I took matters into my own hands and made a little tool. Just thought I'd share with you and see if anyone else thinks this is a good idea and would want to use it. If not, then my development is done, and I've accomplished my goal. If someone does want to use it, I'll have to do some tweaks...like the abilit to recognize different WBO2 PIDs other than the PLX I use.
With my tool, I can:
- Load multiple log files
- Filter out data where the throttle position has changed more than x%
- Filter out data where the throttle is closed and the car is still moving
Thoughts? This will be an LS2 specific tool and requires Microsoft Access to run. I probably can distribute it with a runtime version of Access if there's enough interest.
Gerry
