Results 1 to 6 of 6
Thread: help think i found bug
    May 2004
    FWB Fl
    299
    in the scna below if you the MAP is not reading right...... (in the graph display for it to read right you have change it the MAP "PID" not sensor,
    but even tho it is right in the table display the histgrams do not that reading what is going here?
    http://www.turbov6camaro.com
    1997 Stalled V6 Camaro
    Goal: 10.99 in the 1/4
    Goal: 100 MPH (completed)
    Best Dyno: 456 RWHP and 509 RWTQ
    Best: 1/4 mile 11.23 20 PSI
    Best1/8: 7.18 @ 99 1.83, 60 foot 20 PSI
    28,268
    You probably have that VAC/Boost pid setup as the MAP sensor so when the scanner goes to calculate the sensor it takes (VAC/Boost pid+MAP(SAE))/2=map sensor
    May 2004
    FWB Fl
    299
    Quote Originally Posted by Bill@HPTuners
    how should i set it up?
    28,268
    Don't apply that VAC/Boost pid as a sensor. Just leave that section blank
    May 2004
    FWB Fl
    299
    wont let me leave it blank
    and the list of voltage is all fucked up if i click on my wb or the boost it list all of them???
    May 2004
    FWB Fl
    299
    okay got it but in the linear are there are like a crap ton of listings in there ? why? and how do i know what one is being used? some are the old ones from old senors i had
