Results 1 to 8 of 8
Thread: Maf hi STFT histo not working
    Mar 2008
    3
    just like the title says
    Im using sensor 121 (maf hz ) > 5700 and I get no data Maf lo works?
    Also does anyone have a IFR And Inj offset table for a zo6
    thanks
    Nov 2005
    Houston, TX
    3,968
    [SENS.121] is commanded AFR. [SENS.80] is MAF Freq.
    Bill Winters
    Out of the LSx tuning game
    Mar 2006
    Detroit
    1,023
    Making changes to the top end of the MAF curve based on learned fuel trims (that come from narrowband O2's) is asking fro trouble. You should really be doing this with a wideband.
    Mar 2008
    3
    Im not using it for WOT it is for part throttle crusing and I was going to use the stft as a base like if it adds 10% at 6400hz I would add it all the way for a baseline the car has a jet maf on it also. I tried sensor 80 and it still doesnt work
    by the way good book
    Mar 2008
    3
    never mind it worked hit the wrong number
    5_Liter_Eater
    you wouldnt have any ifr and inj offset tables. this if for a 07 zo6 the table that I have doesn't look right. any help greatly appreciated
    Nov 2005
    Houston, TX
    3,968
    No but there are a few in the repository.
    Bill Winters
    Jun 2007
    1,100
    Quote Originally Posted by eficalibrator
    Exactly...you can only do this without PE enabled and in fiorced closed loop, just to make sure the MAF and VE tables are good.
    You can only really do WOT with PE with a wideband. You can get WOT close by calculating by PE multiplier after you know the MAF is dialed in right, but reading the narrowband sensor under PE mixtures will not give you any accurate indication.
    Jun 2007
    1,100
    BTW: Do you have the right configs to do the MAF vs STFT logging? Just setting a pid in the histogram is not going to make it work.
