Results 1 to 10 of 10
Thread: 4.56 gears not possible with '98 PCM???
    I've got 4.56 gears in my new 9" rearend. When I calculate the tire/gear ratio (26/4.56 = 5.46) and click commit it says invalid entry! It won't let me input anything lower than 6.00. Is there a way to make this work or is it yet another reason '98 cars suck w/tuning software?? I'd really like my speedometer/odometer to read correctly, any help is appreciated.
    '98 Z28 M6: 370ci | twin 6165 | E85
    Jun 2006
    7
    anybody fix this issue just ran in to the same issue?
    Senior Tuner Google's Avatar
    Sep 2010
    Saint Peters, Missouri
    1,303
    Quote Originally Posted by OHIOtuner View Post
    post your tune and tire diameter
    We Can Fix Your Bricked PCM Or Your YYYYYY OS ID
    Jul 2004
    1,579
    Yet another reason '98 suck ... it is a hard coded limit. You are SOL or just disable VSS, or run a taller tire to get above the 6.00 tire/gear ratio.
    Sep 2010
    1,303
    If it is an a4 and transmission shift points are the issue..the trans final drive rpm max is 3839.9 I have calculated a final drive of 3537.18 which will work for a 26" tall tire and 4.56 gears. vss ppd maxs out at 131070 and for correct speed reading you would need 141487.. if you max it out your speedo would be 8% off but your trans will function normal. you will have to scale trans shift mph manually.
    Dec 2008
    on the Dyno
    1,825
    I'd hope someone doesn't have an auto tranny with a 4.56 gear... must be racing to the 330' or something if so haha.
    More reason to upgrade to a 411 PCM! 98's have their quirks.
    Located in Central Kentucky
    ShorTuning
    Sep 2010
    1,303
    Quote Originally Posted by LSxpwrdZ View Post
    I agree on the 0411 upgrade.. But have seen alot of 1/8 mile cars running 456 gears on a4's
    Jun 2006
    7
    Its a 6spd.
    had 411s in there but he wanted 4.56 tried to talk him out but no luck.
    Then find out 98 pcm issue great.
    Of course he is running a stock tire,,,,,don't ask.
    Google thanx i'll try that. I started adjusting these tables but ran out of time.
    Dec 2008
    on the Dyno
    1,825
    Just a thought but I'm not at my computer at the moment that has HPT on it, you could scale the reluctor tooth count by a percentage and alter some numbers to get the speedo working I'm sure. I can't remember if the 98's have access to the reluctor tooth count. I'll look further into that when I can get to my tuning computer.
    ShorTuning
    Dec 2008
    on the Dyno
    1,825
    Okay I looked at a Fbody 98 file here and you can manually go in and scale to the right values. Input these values in the Speedometer->General tab:
    General
    VSS Pulses Per Mile: 60132.000
    Rev-Trans: 17.0
    Final Drive Ratio
    Trans Revolutions/Mile: 3537.187
    This is for a 6spd with a 26" tire and 4.56 gears
    ShorTuning
