I am looking to do some real time tuning but in my OS theres no RTT option under enhanced for my 05 silverado
on some other vehicles im tuning have RTT in there OS
Not available on 05+ operating systems.
Why?Originally Posted by Bill@HPTuners
2005 Pontiac GTO LS2
MY FQUICK - http://www.fquick.com/cyclone_chris
Mods:
K&N Intake | 18" Staggered TSW Thruxton Setup | Toyo T1-R Tires | Billet Products Short Shifter | Kooks 1-3/4" LT Catted headers | NGK TR55 | Ported Stock Intake Manifold | Corsa Sport Exhaust | Polished T/B | FlowTech Streetsweeper V2 Cam | SLP UD Pulley | 160 Thermostat | LS7 Clutch | 39# Ford Blue Giant Injectors | Scorpion Roller Rockers |
445 RWHP/413 RWTQ
I don't believe the 05+ LS1 pcm's had enough extra room in memory to support it with much functionality.
If your referring to 05+ LS2 pcm's(as suggested by your vehicle) its something we'll be looking into hopefully some point over the next developement cycle.
so, we dont have any options besides swapping pcms, gas pedals, etc.....? so we arent even able to any kind of speed density? or we just wont have rtt?
You just won't have RTT.
options????
in my os all the sd options say "not available". is this because i havent purchased any of them?
The 05+ LS1 custom OS's are done on a case by case basis, if you need 1/2 or 3 bar support that isn't available send support an email with your needs, the .hpt file & your serial number & we will try to accomodate you.
-Bill
is it going to cost the same?
yes
thanks for the help
You can run SD on any truck OS, but they do offer a 2Bar custom OS for our PCM right now (which I have licensed). The TAC/Pedal swap works just fine, but to each his own. There's some advantages of cutting better 60' times with doing this mod because the throttle body will open instantly versus a slow ramp rate stock. If you're doing a big cam and need RTT, then the money you spend on an extra pcm and license is nothing compared to a cam swap.Originally Posted by mcfarlnd
'20 AT4
'01 Suburban 2500 Dad Wagon
