Results 1 to 6 of 6
Thread: Afr Pid
    Afr Pid
    When setting up AFR in my PID, I noticed there was 3 listings. AFR ratio error,AFR command Hi res., and AFR command Lo res. Which if any of these 3 should I insert in my PID file in order to log AFR.
    Nov 2005
    Houston, TX
    3,968
    AFR Error is different than AFR Commanded and none of these will tell you your actual AFR. You need to insert the EIO PID for your wide band to tell your AFR. Then you will need to log commanded AFR (either low or high res) to be able to have the AFR Error PID calculate the error. Go with low res.
    Bill Winters
    Out of the LSx tuning game
    I do not understand! Where do I find this (EIO) pid for my LM1
    Nov 2005
    Houston, TX
    3,968
    Do you have the Pro version?
    Bill Winters
    Quote Originally Posted by 5_Liter_Eater
    Yes
    Aug 2005
    Midlothian, VA
    205
    In your table right click in the EIO section and add your Wideband there.
    Mitchell
    '04 Supercharged MC SS
    MOD LIST
    Custom PCM, Ram Air Hood w/ Air box, Intense MPS w/3.6", R/T DP with Ubend delete & HF CAT, LC-1 WB, GMPP Cat Back, Jacobs wires, 180 T-stat, & an Optima Red Top
